ecu swop out is it as easy as that
Old Nov 14, 2020 | 08:13 PM
ray barker's Avatar
ray barker
Default ecu swop out is it as easy as that
hi folks just bought another l6 ecu to replace my fried one. the second hand one i just bought was running greens i didnt want the chip with it so its been taken out. is it just as simple as putting my stg1 chip in it and away i go or will i have to adjust the co or anything els as the co screw might be in a different position for the previous owners set up being it was running greens thanks. i no its allways best to have a set up. i do have a co machine
Old Nov 15, 2020 | 06:30 PM
ray barker's Avatar
ray barker
anyone i dont want to shaft this one as well
Old Nov 15, 2020 | 07:25 PM
martysmartie's Avatar
martysmartie
Yes, swap the EPROM (chip) out. You should check/set the CO though.
Martin
Old Nov 15, 2020 | 08:29 PM
ray barker's Avatar
ray barker
Martin
you are the main man marty thanks for your help
Jan300
Oct 26, 2016 06:29 AM
James Porter
Mar 3, 2014 08:12 PM
bigd2
Aug 30, 2009 09:21 PM
raggey
Apr 17, 2009 08:58 PM
205bhprst
Oct 27, 2004 11:27 PM
