ABS
Evening all
probably been asked a millions times but what is the correct/best way to run pipe setups after ABS is removed
the reason I ask is the S2 I have purchased is on standard brakes but ABS removed, it still has both valves on the rear arms it the brakes are shocking.
car is not yet back to my workshop so will get some picture up when it does land and get it up on a ramp see what I’m dealing with over winter
any pictures or pipe layout would be very helpful
thanks in advance
thanks in advance
turboloon
Mar 7, 2007 04:40 PM
