Cossie 4x4 Turbo fitted to an Rs turbo step by step
I have fitted a Cossie 4X4 T3 to a Rs Turbo, however i wondered if a step by step would be useful for anyone? its all in bits again so is easy enuff to do with piccies etc so would anyone be interested in this at all?
no use at all to me but will be an enjoyable read anyway
No i mean fitting a cossie T3 to an ERST, as its not the easiest job in the world to be honest imo, even with a specially made adapter to mate to the manifold
Ive dont it - not the easiest job lol. U have to rotate both housings on the core so that all the oil/water feeds line up, and then modify the bracket so the actuator lines up. My exhaust is modded to bolt straight onto the exhasut housing.
Got 1 fitted to mine its got a saab turbo .48 housing on it with a little time it fitted straight on.aint a clue what saab it come off but it works fine did need to use a gasket in between manifold turbo join as it was blowing apart from that no probs
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
