Mk2 focus 1.8 diesel to 1.6 petrol from mk1
Hi all,
I currently have a 1.8tdci mk2 focus and have a 1.6 petrol mk1 focus as a “donor” car, will the whole front suspension subframe struts engine gearbox with the 1.6 loom and everything fit or is it different from mk1 to mk2? Are there any other problems I would need to worry about like gear cables? Or subframe mounts.
Thank you Austin.
Thank you Austin.
To be honest it would be easier to get shot of both cars and just buy a 1.6 16v petrol.
Me and the Mrs own a mk2.5 1.6 16v petrol and to be honest its flat as a fart.
It would be interesting if you could swap the engines over but no doubt it won't be that easy. The wifes focus has fly by wire throttle,no throttle cable.
Conor Harrington
Dec 24, 2009 04:44 PM
