Focus ST 225 not starting
Old Aug 17, 2020 | 08:45 AM
OrionRST200bhp's Avatar
OrionRST200bhp
Default Focus ST 225 not starting
Hey, I’m looking for some advice on an issue I have with a st225, I picked the car up the other day, drove it 10miles home, it drove really well and boosted fine, done what it was suppose to do, I parked it up on the drive, came to start it the next day to move it and it just turned over and over and over, and still is turning over and over, theres nothing coming up on the diagnostics reader, the battery is a bit crap I must admit, there’s new plugs in there and half a tank of fuel, so hopefully I can rule that out, any ideas would be greatly appreciated.
Old Aug 17, 2020 | 12:39 PM
Cookson's Avatar
Cookson
10 Year Member
Crank sensor?
Old Aug 17, 2020 | 12:40 PM
OrionRST200bhp
Originally Posted by Cookson
Crank sensor?
I do have another crank sensor, was about to try it. Fingers crossed.
Old Aug 17, 2020 | 01:22 PM
OrionRST200bhp
Still no joy.
Old Aug 17, 2020 | 07:19 PM
Is the fuel pump priming.
Old Aug 17, 2020 | 07:21 PM
OrionRST200bhp
Yea pump is priming there’s fuel getting to the chambers
Old Aug 17, 2020 | 07:27 PM
I take you have checked for a spark??
Old Aug 17, 2020 | 07:57 PM
boost monster's Avatar
boost monster
Doesn’t the instrument cluster suffer from dry joints on these and if you bang the top of the dash they can start!! Maybe an old wife’s tale
Old Aug 17, 2020 | 08:15 PM
Is the immobiliser working correctly?
Old Aug 17, 2020 | 08:30 PM
OrionRST200bhp
I’m assuming so Glenn
Old Aug 17, 2020 | 10:53 PM
GVK.'s Avatar
GVK.
If the cluster is faulty it won't even crank over as the cluster is part of immobiliser.
Have you checked the cam belt is actually turning?
Old Aug 18, 2020 | 05:55 AM
OrionRST200bhp
cambelt is turning. It’s cranking fine, just no spark, hopefully got someone coming to look at it today.
Old Aug 19, 2020 | 10:31 AM
OrionRST200bhp
Diagnostics came up with faults in instrument cluster
Old Aug 19, 2020 | 01:15 PM
GVK.'s Avatar
GVK.
Were they U codes do you know,? When you scan those cars they very often come up with U codes which are lack of comms between modules and don't often have any effect on the car.
Old Mar 12, 2024 | 07:27 PM
Anthony Solomon's Avatar
Anthony Solomon
Did U get to the bottom of this
Old Mar 13, 2024 | 11:29 AM
OrionRST200bhp
hi mate, I sold the car as spares or repairs, the new owner said the head gasket had gone, it must have literally gone as I parked the car up from collecting it, I’ve heard that head gasket failure can cause these issues but, I’ve had ST’s with really bad head gaskets in the past and they still manage to start eventually. Hope you haven’t got an issues like this with yours.
Old Mar 14, 2024 | 11:26 PM
Anthony Solomon
That seems strange to go like that mine was the same running fine did 1200 miles just to day B4 this next day still going fine parked at night and next morning it started but was missing then it cut out and it's not started since
Jak Moore
Jul 4, 2019 11:08 AM
danlauramia
Dec 18, 2009 05:24 PM
MAD EVO 4
Feb 16, 2006 03:13 PM
