Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
hole in the floor
Old Jul 23, 2020 | 09:34 PM
Robsters's Avatar
Robsters
Default hole in the floor
so found a hole in the floor of my car today on the passenger side...it is fairly bad....there is a picture below... it looks like rust but it is infact the tarmac below (inside the red circle). The sill and the main floor on the rest of the car all seems very solid.... so for some strange reason its completely rotted in this one area on the car....I have no idea why but the good news is that the rest is all ok! my question is
1. is it a safety issue ? as the sill and rest the floor ok... the hole is located between sill and the floor so not sure if its a structural issue?
2. if its not a safety issue should i just fill it with fibreglass or get it welded ?
MOT 3 months away so good job i spotted it now !
Old Jul 24, 2020 | 10:49 AM
haz87's Avatar
haz87
Nah why would the floorpan need to be attached to the sill with metal - just slap fibreglass or some silly putty on it :P
Yes its a pretty integral join in the grand scheme, so get it welded. Thankfully its a pretty easy area to cut out (to clean metal) and get a decent rectangular piece shaped up to drop in. Not a hard job really even for a DIY welder with some patience. Prep is key tho if you don't want to be doing it again in 12 months, theres clearly alot more rust sitting under the remaining paint and probably under that plastic sill trim, so either cut it all out, or take it right back to clean metal with a flap disc or wire brush and see if theres strength in whats left to weld to.
Old Jul 24, 2020 | 12:20 PM
Robsters's Avatar
Robsters
ha yeah thanks well reason i asked as the hole not that big at the moment and rest of the car seems fine. but front of sill that side looks bit rusted but the hammer does not go through it and i hit it pretty hard to make sure. unlike that bit where the hammer goes right through. I will look for a welder...
Old Jul 24, 2020 | 02:14 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Don't fuck about get it cut out and repaired if you cant do it yourself save up then take it somewhere who knows what there doing. but if it ends up needing inner outer sills and a floor pan repair plus paint I can see it being over a grand if honest
Old Jul 24, 2020 | 03:24 PM
Robsters's Avatar
Robsters
yeah i plan to get it welded does anyone on here know of any mobile welders in the berkshire area? a grand would be mental price and be more then the car is worth for sure.
Old Jul 24, 2020 | 05:42 PM
ajamesc's Avatar
ajamesc
That’s doing it properly and cutting out all the rust as no doubt once you start there be loads more. If it’s a car your not really bothered about any joey can patch it outside your house for a few hundred
Old Jul 24, 2020 | 06:12 PM
Robsters's Avatar
Robsters
if it 1k to fix it will have to be a patch job for now in these uncertain times as in no place to be buying another car
xr2irhys
Fiesta's Other !
Mar 17, 2024 01:18 AM
notroubleclubber
Sep 17, 2008 09:21 PM
20
Jun 11, 2005 11:54 AM
Alan s1
Oct 3, 2004 10:09 PM
