ISCV alternative
Old Jul 23, 2020 | 04:06 PM
bob le routier's Avatar
bob le routier
10 Year Member
Default ISCV alternative
Hello,
I would like to know if someone installed something different from the genuine ISCV.
I got some troubles to manage the ISCV valve and I am looking for something different, for exemple a remote solenoid.
The tune of the ECU won't be a problem, it's most about how to close the orrifices of the throttle body.
Regards !
Old Jul 23, 2020 | 09:35 PM
christos's Avatar
christos
10 Year Member
Hi, you can use this valve... this is for peugeot, citroen and its much cheaper than ford's iscv.
Only thing you must is to put plug upside-down due to different position of 12v dc.
Old Jul 23, 2020 | 09:37 PM
christos's Avatar
christos
10 Year Member
its a genuine marelli valve and its work perfect for me from cold start...
Old Jul 24, 2020 | 03:40 AM
bob le routier
10 Year Member
Good to know ! Thank for the pics with the reference !
I am a little bit affraid to use again the genuine ISCV, I got full open uncommanded position just after start several times with genuine ECU and niew tunable ECU with new loom... It's not a nice joke when your engine took 2000 rpm after not running for 3 months. Fortunately, I had perform a dry start with the unplugged injector to set oil press before regular start...
Old Jul 29, 2020 | 08:09 AM
cossynut2's Avatar
cossynut2
10 Year Member
Good information Christos, I did not realise anything other than a genuine Ford one was suitable.
Old Jul 30, 2020 | 03:33 PM
christos's Avatar
christos
10 Year Member
Thank you!
Old Jul 30, 2020 | 03:53 PM
christos's Avatar
christos
10 Year Member
col93saphcos
Apr 14, 2012 02:39 PM
warrenja1
20
Nov 29, 2008 12:49 PM
Roosie
23
Oct 17, 2008 08:26 AM
NEWTON
24
Apr 4, 2008 12:20 AM
rs nuts
Jan 11, 2005 07:30 AM
