Rev counter not working
Old Jul 23, 2020 | 10:55 AM
Pd1970's Avatar
Pd1970
Default Rev counter not working
Hi all new to this forum ,question is just bought a mk3 escort 1.6 ghia now with 2.0 zetec in running on 40webers & the Rev counter doesn’t work?. I’ve no idea what Ecu/ harness its using ,could anyone point me in the right direction to get it working thanks
Old Jul 23, 2020 | 03:21 PM
XR2's Avatar
XR2
Depends on the ignition setup.
Ford EDIS (standalone)?
Aftermarket ECU?
Distributor conversion?
Old Jul 23, 2020 | 05:39 PM
Pd1970's Avatar
Pd1970
It’s a nodiz pro Ecu if that helps
Old Jul 23, 2020 | 06:37 PM
XR2's Avatar
XR2
Yes it does.
The Nodiz pro has a rev counter output (PIN2, check your handbook page 12; "6.2 Main loom connecting") that is not part of the standard Nodiz wiring loom and you might have to install a pin and cable first. When this won't work or your rev counter gives you wrong or half readings... try this:
https://passionford.com/forum/ford-e...v-counter.html
white2lsr
May 14, 2010 07:31 PM
wayne2009
Dec 20, 2009 06:20 PM
Alan s1
Mar 14, 2008 12:06 PM
Diablo
Jan 12, 2005 08:32 PM
Krazy Kim
11
Nov 15, 2004 08:24 PM
