Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Improving the Cortina Mk3/4/5 rear end
Old Jul 17, 2020 | 12:57 PM
Rschofield's Avatar
Rschofield
Default Improving the Cortina Mk3/4/5 rear end
Hello, I'm restoring a kit car that has a fairly standard Cortina rear end with an Atlas axle.
It has the wobbly four link with the upper arms making a "V" shape.
I'm thinking I'd like to tighten up the side to side movement.
I assume a panhard rod is a no go as it will have a defined arc side to side movement that may not "agree" with the upper arms. Am I over thinking this?
Would Watts linkage work?
Would I need to modify the original four links with watts or can they stay as is?
Assume they wouldn't all need to be parallel with eachother?
Any help would be greatly appreciated.
Old Jul 17, 2020 | 01:19 PM
focusv8's Avatar
focusv8
Panhard is a cheap and cheerful fix if you don't want to rebuild the rear, make it adjustable so it can be set after install.
It's used by Ford on 2005 to 2014 Mustangs, non adjust as they already know the correct standard length.
Old Jul 18, 2020 | 08:07 AM
Rschofield's Avatar
Rschofield
I can't see the upper arms in that image. Do they resist sidewards movement?
My fear of putting a panhard on a Corrina setup is that the upper arms are trying to resist sidewards movement (albeit badly) and the panhard forces sidewards movement with a great deal of force.
Maybe the bushes could handle this?
Or maybe they will disintegrate, or worse, bend something.
Old Jul 18, 2020 | 09:28 AM
focusv8's Avatar
focusv8
Just a single centre mount.
Top of the diff is on the right.
Old Jul 23, 2020 | 02:53 PM
Rschofield's Avatar
Rschofield
Ah, I see, that makes more sense.
So your three links are all parallel so running a panhard is a good route as you can allow that side to side movement.
I wouldn't be able to bolt on a new links like you have as my body is GRP so would need to fabricate something bespoke to mount to the chassis.
Unless it's not a problem fitting a panhard to non parallel four link.
bicko
Ford Mondeo Including ST
Jul 20, 2016 12:42 PM
