3dr Cosworth not starting - no fuel to fuel rail
Old Jul 16, 2020 | 07:18 PM
Rodge.'s Avatar
Rodge.
Default 3dr Cosworth not starting - no fuel to fuel rail
This car is testing my patience
Took the car off the road last year to tidy it up - ended up being a full on restoration as per usual
Almost finished but it won't start. It will run if i put a splash of fuel into the plenum but won't fire up on it's own.
I just noticed today that there is no fuel at the fuel rail however there is around 7-8 bar just before the fuel pressure regulator. Regulator is new bought last month from MSD so doubt it's faulty?
As part of the resto, I have replaced the following with new:
Crank sensor
Phase sensor
Map sensor (3 bar)
Coolant Temp sensor
ISCV
Fuel Pressure regulator.
New pump
New fuel filter
Uprated pump loom
Green 803's been cleaned and flow tested
MSD chip
L6 ECU with wasted spark
Anyone any ideas? Canl;t understand why there would be no fuel at the rail.
Old Jul 16, 2020 | 08:16 PM
bigdel's Avatar
bigdel
So where do you have 7-8 bar? At the bottom of the regulator on the left, or at the inlet on the right hand side of the rail
Old Jul 16, 2020 | 08:48 PM
Rodge.'s Avatar
Rodge.
I think you've nailed it tbh!
I thought the inlet was under the fuel pressure regulator and the return was on the rail itself!
I've replaced the fuel lines too with new - I think I have them the wrong way round!
Will check tomorrow!
Old Jul 17, 2020 | 04:26 PM
Rodge.'s Avatar
Rodge.
Ok, after reversing the new fuel lines I now have fuel at the fuel rail - too much by the looks of it!
It's flooding the cylinders!
If I unplug the injectors, it stops..
Fecking car!
Old Jul 18, 2020 | 04:08 PM
martysmartie's Avatar
martysmartie
Fecking car!
Is this with the ignition on, or when cranking?
Martin
Old Jul 23, 2020 | 02:33 PM
Rodge.'s Avatar
Rodge.
Martin
Just when cranking. I have bought another ECU to test so we will see whaty happens with that when it arrives.
Old Jul 23, 2020 | 04:49 PM
Rodge.'s Avatar
Rodge.
OK, got the new ECU and it now runs
Only slightly strange thing is it came with a uprated chip fitted as well as a wasted spark board. Fitted it and it fired up straight away.
However when I fit the MSD chip I bought 3 weeks ago, it doesn't run
Starting to wonder if that's been the problem all along!
Old Jul 24, 2020 | 10:41 AM
gcfcos's Avatar
gcfcos
Awesome you got it running. Shame about the chip!
Old Jul 26, 2020 | 12:34 PM
Rodge.'s Avatar
Rodge.
Think I've figured out why.
The ECU I bought was supposed to be a L6 but looks like a L1 so that's why my MSD chip won't work in it.
The seller says it's a Bayjoo chip - is there any way of finding out what the spec might be from the sticker on top?
The top of the chip says "3BL1R26.803" which (as a guess) I'm thinking:
3 bar sensor
L1 ECU
R26 - no idea
803 - greens
Might be totally wrong though
Old Jul 27, 2020 | 06:06 AM
gcfcos's Avatar
gcfcos
3 bar sensor
L1 ECU
R26 - no idea
803 - greens
Exactly what I was thinking lol. I've not heard of an L1 ecu before only L6 and L8. What were they out of?
Edited to say I've just googled it and found out was 3 doors lol.
Old Jul 27, 2020 | 09:15 PM
martysmartie
Yes, L1=3 DR. L6 is essentially the same, but electronics are different, hence you can not interchange EPROM's.
L8 has double the memory, hence can run thing like ALS etc and BT Escos improved further with P8.
Your thinking is logical, however I would never use a secondhand calibration, as you simply don't (and can't) know what it is, you can't rely on what a label suggests.
Martin
Old Jul 28, 2020 | 12:51 PM
Rodge.'s Avatar
Rodge.
Martin
Thanks, not planning to use the chip long term, just wondered if there was any easy way of finding out the spec of it from the number.
Stu at MSD is doing me another chip for my spec but L1 instead of L6.
With hindsight I should have just bought a L8 when I was buying a replacement ECU but the new one was supposed to be the same as my old one to save changing the chip spec again.... which I had to do anyway
Old Jul 28, 2020 | 10:11 PM
martysmartie
Yes and no, MSD for example keep a database with S/N and calibrations, but what’s to say the EPROM has not been reprogrammed in the past?
Unless you can read it (and even then you would have to understand mapping) you simply don’t know 100%.
For this reason, I would never buy (nor trust) a second hand EPROM, despite what it may claim to be, it’s simply not worth the risk.
Martin
Old Jul 30, 2020 | 07:58 AM
Rodge.'s Avatar
Rodge.
Well, new MSD chip fitted again and all seems well
Now I just need to sort out a breather - what's the best these days? Both sides of the block? Would rather not drill the cam cover.
I saw this fitting kit on Burton's page. Does the bit on the left replace the plug underneath the exhaust manifold?
X8MRK
Oct 5, 2013 09:02 AM
SaqsS2turbo
Mar 30, 2007 11:25 PM
melzieann
Feb 18, 2007 02:09 PM
pete mcrash
11
Dec 6, 2006 08:39 PM
