2wd coolant issue
Old Jun 27, 2020 | 07:51 PM
killa_paul's Avatar
killa_paul
Default 2wd coolant issue
Driving down the road after an hours drive the car had been running fine , heater was on a little gave it some beans then all of a sudden loads of steam then coolant came flying through the air vents , turned the heater off slowed down , and coolant running down near the water pump ,.. guessing the water pump or something has gone and its over pressurised and blown something . hopefully no other damage dipped the oil and it wasn't milky put it away and going to start investigation tomorrow , the joys of owning a cosworth !!!
has this happened to any of you before ?
Old Jun 28, 2020 | 12:01 PM
cossie2's Avatar
cossie2
..probably just water pump gasket ....but check if the pump seal leaks..there is a small hole on the body of the pump,,it will leak from there if the seal fails
Old Jun 29, 2020 | 02:41 AM
4x4kiwi's Avatar
4x4kiwi
The only way I can see how "loads of steam then coolant came flying through the air vents" would be if the heater matrix had sprung a leak suddenly while under pressure.
David
Old Jun 29, 2020 | 04:37 PM
Mondi-DZK's Avatar
Mondi-DZK
I've had the same, also been driving for an hour and everything ok. But first thing I noticed was temperature light came on. Pulled over and stopped. But already lots of steam and coolant all gone.
​​​​​​It started with a crack in a coolinghose.
Turned out head gasket was gone to. Small engine revision and replaced all hoses and new waterpump and gaskets to offcourse.
​​​​​​Hopefully it's just the waterpump for you.
greets
daftcowuk
Jun 21, 2023 05:50 PM
Robsters
Apr 30, 2017 10:41 PM
Breambasher
Ford Mondeo Including ST
Jan 31, 2012 11:13 AM
terribletaj
Apr 11, 2010 07:32 PM
simps
Mar 10, 2010 08:00 PM
