Saph cossie head lights.
Old Jun 26, 2020 | 07:09 PM
Default Saph cossie head lights.
Does anyone have pics of what the correct headlights that should be fitted to 4x4 saph cossies.
I've got Carello ones in my saph. There is a 3 digits next to the name in the headlight lense? Is that correct?? The digits/number is 913..All the headlights ive seen on ebay that are carello lights don't have to number next to the name.
Old Jun 26, 2020 | 08:24 PM
qed296's Avatar
qed296
Hi Glenn.....mine have the number after the name stamp.....
614......
I have a plane glass with no number but the lamp body looks to be from a standard sapphire as it has the 2 grill mounting points
Old Jun 26, 2020 | 10:38 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Carello 899 and 900 give a very fresh look. Have them on mine.
Old Jun 27, 2020 | 07:53 AM
614......
Yeh mine has that number on the drivers side headlight.
Old Jun 27, 2020 | 10:10 AM
qed296's Avatar
qed296
Just had alook and both lamps have the number on....the spare plane glass is on a lamp from a standard car.
I wonder if its a batch number or there is in fact different models fitted to cosworths, headlight leveling?? Was that ever fitted??
Old Jun 27, 2020 | 12:00 PM
Electric head light adjustment was on cossies that were sold abroad.
Old Jun 28, 2020 | 07:43 AM
Marc sierra's Avatar
Marc sierra
What’s the difference? Is it another type of glass?
Old Jun 28, 2020 | 11:34 AM
qed296's Avatar
qed296
So i need my eyes testing.....the o/s lamp is 814 and the n/s is 813
I have another set matching these and another 4 units that have plain glass with just Carello on.
Old Jun 28, 2020 | 03:04 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
The vertical lines that are pressed into the glasses themself are less hard and therefor less noticable
which give them a more clear and fresh look.
Especially when you compare them to the Bosch headlight glasses.
Old Jun 28, 2020 | 07:48 PM
Marc sierra
Interesting. I have no idea what head lights I have. I think they are bosch, but not sure.
Old Jun 29, 2020 | 07:59 AM
cossynut2's Avatar
cossynut2
10 Year Member
I wonder if the 2 different numbers denote right and left headlights?
Old Jun 30, 2020 | 08:00 AM
Marc sierra
One number is indeed probably for left and the other for right. But there will also be a difference between LHD and RHD head lights. So the 813/814 are probably RHD and 899/900 will be LHD.
Old Jun 30, 2020 | 08:22 AM
cossynut2's Avatar
cossynut2
10 Year Member
That makes sense Marc unless someone else has another explanation.
Old Jul 1, 2020 | 04:16 AM
All the carello hesdlights I've seen for sale only have the name on the glass and not the numbers.
I'm after a head light for the drivers front cause the chrome part is starting to look tatty.
Old Jul 3, 2020 | 11:32 AM
cossynut2's Avatar
cossynut2
10 Year Member
Hi Glenn, I took my Saff out today and both of my headlights are the same with Carello on the top and H4 on the bottom of the glass 2wd 1990.
Old Jul 5, 2020 | 08:37 AM
So are you hwadlights the same as mine with the 3 numbers next to the carello name??
I aas out in my saph yesterday too.
Old Jul 5, 2020 | 05:49 PM
cossynut2's Avatar
cossynut2
10 Year Member
Hi Glenn, my headlights are different to yours, the carello name is at the top of the glass and the numbers are below on their own. Maybe 2wd and 4wd are different?
Old Jul 5, 2020 | 08:53 PM
james kiely's Avatar
james kiely
2wd and 4wd headlight are different
Old Jul 15, 2020 | 08:51 AM
Whats different about them James??
KSA-Cossie
Dec 14, 2014 09:15 PM
dans rst
Apr 30, 2009 09:05 PM
FlashRS
Jan 25, 2009 09:58 AM
YBJ
Mar 31, 2005 05:11 PM
