Mk3 orion rebuild
Old Jun 20, 2020 | 12:55 AM
escozzyno1's Avatar
escozzyno1
Rstorion
Default Mk3 orion rebuild
So heres a brief description of my car and its past, ive owned this car for 14yrs, i bought it of a mate and used it for around a yr then parked it up, i dont have any pictures from then but i do from a couple of yrs ago that i will upload of my old phone, i had the idea when i was young to make it into a track car so i regrettably ripped apart my escort rs turbo for the engine and box and sold the rolling shell on ebay for £690 but if only i knew then what i know now ha. So i basically made the car have more power, put some koni adjustables on, ripped the interior out and skipped it which i also now regret, and i thought yes ive got a cheap toy for odd weekend but fast forward 12years and this is the car now feeling very sorry for itself and in need of some work to say the least, i did put it on axle stands 3years ago to start fully rebuilding it but that also never happened but now its a must i need to save the old girl lol, she does need some work underneath the inner sills/ floor have gone etc i did start grinding all this back around 18mth ago ready to cut it all out but that also stopped. I will upload more pics of the welding task i have,wish me luck
Old Jun 20, 2020 | 07:55 AM
st220kyle's Avatar
st220kyle
Nice to see someone giving an Orion some love, I had one as my first car about 16 years ago.
keep us updated with how you get on 👍
Old Jun 20, 2020 | 09:52 AM
escozzyno1's Avatar
escozzyno1
Rstorion
I will do it does need alot of work as i cant get any floor pans or inner sills from anywhere nobody does them for this model but ull see once i upload all the pics, this was also my first car so kept it in a garage but it was out of sight out of mind and now i can no longer use the garage so the car has to be moved so its time i sorted it lol
Old Jun 20, 2020 | 09:58 AM
Rsmat's Avatar
Rsmat
Good look with it , be nice to see the progress.
Old Jun 20, 2020 | 12:23 PM
escozzyno1's Avatar
escozzyno1
Rstorion
cheers bud, ive seen what uve done with your escort been a good read uve done a great job there
Old Jun 20, 2020 | 01:22 PM
Rsmat's Avatar
Rsmat
Any time mate , and thanks it's been a joy to build.
Old Jun 20, 2020 | 08:37 PM
escozzyno1's Avatar
escozzyno1
Rstorion
Before it went on axle stands around 2-3yrs ago
Old Jun 20, 2020 | 08:45 PM
escozzyno1's Avatar
escozzyno1
Rstorion
Old Jun 20, 2020 | 08:50 PM
escozzyno1's Avatar
escozzyno1
Rstorion
Old Jun 20, 2020 | 08:52 PM
escozzyno1's Avatar
escozzyno1
Rstorion
Old Jun 20, 2020 | 09:13 PM
escozzyno1's Avatar
escozzyno1
Rstorion
Once it was up on the axle stands i thought id start stripping everything of underneath to be cleaned and powder coated and then of to the bodyshop for a full respray thinking thats all id need to do as around 6-7 years ago i had new outer sills put on at a garage and they said it was solid bar the sills i then had it wax oiled once a yr so didnt worry about it needing any welding etc but as ull soon see i discovered more than i bargained for.......
Old Jun 20, 2020 | 09:18 PM
escozzyno1's Avatar
escozzyno1
Rstorion
Old Jun 20, 2020 | 10:09 PM
escozzyno1's Avatar
escozzyno1
Rstorion
Once stripping all the parts from underneath i had a closer inspection of the sills and floors and thought id see how solid it was as i noticed a small area that was bulging through the 95 layers of underseal lol. So i attacked the inner sill/floors on the passenger side with a pry bar and grinder and this is what i found.........(this is 2yrs ago)
Passenger side front inner sill and floor
Passenger side inner sill and floor in the centre area
Passenger side inner sill/floor towards the rear door
as you can see the garage i took it to did a half job they put the outer sills on then made l-shaped plates welded to the floor and the lip of the sill and didnt cut the old metal out then on top of that they put a smooth layer of body filler over the top of it and undersealed so when i took a look at it it looked like a neat job but was really a well hidden botch. Ive not started investigating the drivers side but it will be the same, once the car has been moved to its new location i will be doing all the welding there for now i need to get it back on its wheels to move it from where it is.
Old Jun 20, 2020 | 10:34 PM
escozzyno1's Avatar
escozzyno1
Rstorion
Fast forward to today and this is everything ive found welding wise
Well and truely wrotten, i have bought the repair panel for this
As previous picture shows this is the passenger inner sill/floor but with surface rust from were i previously ground it back
Passenger rear floor, will definately go through with the bar so this will be cut out and welded
Peek a boo i created a hole today this is the drivers side front inner sill/floor
Drivers side front floor were i created the hole on previous pic
This is a view from the drivers side rear arch looking down inside the drivers side sill
This is a view from the drivers side rear looking down the sill from underneath as you can see i havent poked this side and it looks ok but it definately wont be
Rear end of the car underneath
GarethRS
Oct 10, 2011 08:41 PM
webby80
25
May 14, 2010 10:30 PM
GHAFRS
74
Aug 25, 2009 07:21 AM
hlev
14
Jul 10, 2007 12:00 PM
