Sapphire turbo lag
Old Jun 4, 2020 | 08:29 PM
timsrs's Avatar
timsrs
Default Sapphire turbo lag
Just got my car going after a resto
The engine is as follows
202 block with valve cutouts
standard head
BD14 inlet
BD10 exhaust
70mm pro alloy intercooler
T38/.48 specked by turbo performance
2wd exhaust manifold
4x4 inlet
plenum spacer (10mm )
L8 ECU
it’d seems a bit laggy from what I’m normally used to
It runs fine and goes really well when turbo gets there
boost starts to come on around 3500fpm
it’s going for a final MAP but don’t think it will improve the turbo lag
what’s your expert thoughts
thanks all.
Old Jun 5, 2020 | 07:56 AM
cossie2's Avatar
cossie2
...Have you checked cam timings...i think with this set up oe cams will work much better..at least i would change the exhaust one..
Old Jun 5, 2020 | 08:57 AM
smiley's Avatar
smiley
What's your tuner say about it Tim?
Old Jun 5, 2020 | 10:51 AM
christos's Avatar
christos
10 Year Member
Laggy with a T34.48 turbo? It shouldn't be laggy..
Something else mate,202 engine block is from ford transit?
Regards
Old Jun 5, 2020 | 12:27 PM
timsrs's Avatar
timsrs
Ive yet to speak with them and take it for live mapping
I know the BD10 will make it laggy low down
The turbo is a T38/48 Harvey Gibbs uses them with great results
lockie
21
Oct 8, 2015 08:01 PM
pope11787
Jul 27, 2010 10:57 AM
forevaford
Jun 6, 2010 09:35 PM
pieterjan
13
Apr 20, 2009 08:07 PM
Dunccoss
15
Mar 14, 2008 11:47 PM
