Cosworth amplifier
Old May 22, 2020 | 06:44 PM
CHUNKYS RS's Avatar
CHUNKYS RS
Default Cosworth amplifier
Hi iam looking for some help with my amp has anyone got the amp lead with a din plug 1 end and a block connector the other end that they could test and tell me the pin outs so I can make 1 as I can’t find 1 anywhere
I know it’s 5 wires from the radio to the amp but not sure which pins on the din connector can’t find a wiring diagram ether any help would be great
Old May 23, 2020 | 09:55 AM
4x4kiwi's Avatar
4x4kiwi
Not sure if this is what you after but circuit diagram attached
David
File Type: pdf
Old May 23, 2020 | 05:30 PM
CHUNKYS RS's Avatar
CHUNKYS RS
This is the lead iam missing ,I can make out the pins on the flat connector but need the pin out for the din connector so I can make 1 ,I looked inside the amp and only 4 pins are connected to the din plug
RS-Stian
Aug 5, 2017 01:47 PM
Cossy Mike
11
May 18, 2015 07:30 PM
nordlead75
Ford Escort RS Cosworth
Apr 19, 2015 10:39 AM
glennjolly
Jul 6, 2014 10:55 AM
jordan99940
13
Feb 25, 2010 12:54 AM
