Removing 19 tyre with a manual eBay machine
looks like a right chew on.
I used a tyre machine at my work a few weeks back. The rim popped off the machine and the arm caught the rim which has damaged it. Ahhhhh I wish I paid someone to do the tyres now ha ha.
if I can find the bits in the garage I will make an assist arm for it, and see what difference that makes.... I only bought the machine because I was board on eBay
i would happily do a perfect smaller rim or a bigger rim with a higher profile, but to be honest now I have done it once and kind of learnt a way of doing it I think nylon covered tools would be ok, that rim was already crazed but it didnt get any deep scratches.
the video was more an is it possible on a 19. I changed a valve stem on my trailer and the ฃ10- 15 Saving that made and the fact know where was open to do it has paid for the machine in my eyes,
since I bought the machine I have has a tyre fitted professionally on my 18 diamond cuts on one car and the other is due a run flat, that will also be getting done professionally,
I bought some used 13 for my metro that needed the tyres taking off so its really convenient for bits like that
theres not much flex in a low profile 19 inch tyre . that would be a right pain doing them often. ive had a blowout on the motorway in a 265 x 30 x 19 and you hardly feel it because of the low profile.
lol. I welded a box section into it, the pin has started to wear out the hole in the tube so I will be welding a tube in to spread the load, that was damaged on a rusty steel wheel,
the bead on the 19s wasnt actually that bad
the1da
Dec 5, 2017 09:41 PM
zaki
Sep 9, 2005 06:22 PM
