over heating when idleing
hi im new to this . my car a 1.8 petrol ford focus 2005 is overheating when in traffic and fans not kicking in also ac not working could this be connected to temp sensor and where would it be found plz help
...Do you have enogh coolant in the tank?air lock maybe ....if this is fine try bridge over the temp sensor on radiator to see if the fans are working or easier remove relay and bridge two connectors...hopefully is something simple
graham ascough
Apr 1, 2014 06:26 AM
bigneil84
Ford Focus (All Models)
Jul 15, 2011 02:02 PM
