Tvr t5 gearbox
Old May 17, 2020 | 10:30 AM
stevecfrst1's Avatar
stevecfrst1
Default Tvr t5 gearbox
Has anyone fitted a tvr t5 gearbox to a 2wd cosworth? There supposed to be a lot stronger than the cosworth box, and pretty reasonable price. Been looking at doing the quaife big tooth conversion to my box but its expensive to do. Thanks
Old May 17, 2020 | 11:17 AM
turnover's Avatar
turnover
Yes Steve fitted one in my escort when I built it ,but had to replace the rear tail housing as gear lever in the wrong position
Old May 17, 2020 | 10:59 PM
turbotrev's Avatar
turbotrev
They are no stronger, basically the same box.
If your after an option as cheap as possible just get your current t5 rebuilt.
Cheers Paul
Old May 18, 2020 | 11:45 AM
turnover's Avatar
turnover
Cheers Paul
think they are stronger as made by tremec not Borg Warner also the tvr make more torque and power than a ybt I might be wrong no idea,but it was still no good on the high rpm gear change from 2nd to 3rd so had quaffe internals put in then never had a problem with the shifts
Old May 18, 2020 | 12:32 PM
stevecfrst1
Spoke to cts today and they say there exactly the same. Ideally I would like to find a used t5 with a quaife big tooth kit in it allready, there very hard to find though. Bit of a stretch for me to find the money for a new one at the mo
Old May 18, 2020 | 05:44 PM
turnover's Avatar
turnover
How much is the quaife kit these days
Old May 18, 2020 | 06:37 PM
stevecfrst1
Its Ł1945+vat fitted
Old May 18, 2020 | 09:30 PM
Adam-M's Avatar
Adam-M
Is that price plus synchros and bearings?
Old May 18, 2020 | 11:56 PM
turnover's Avatar
turnover
Sounds about right think mine was Ł1700 like 10 years ago
Old May 19, 2020 | 07:07 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I just sold one for 1700
Old May 19, 2020 | 07:34 AM
nixon_2wd's Avatar
nixon_2wd
They're identical. Same gears, same syncros. No stronger.
Old May 19, 2020 | 02:55 PM
Adam-M's Avatar
Adam-M
Thats what I suspected, they don’t get abused like have you ever seen a tvr doing burnouts lol and the power delivery will be smooth.
Old May 19, 2020 | 03:18 PM
BIL N KEL's Avatar
BIL N KEL
exactly what I was thinking! I bet not many tvr’s have had a few 2nd gear clutch kicks 😂
cossiedan1983
May 8, 2009 03:46 PM
coachworz
Jul 18, 2008 09:12 PM
abdr500
77
Feb 10, 2008 08:53 AM
