Wanted
Old Apr 29, 2020 | 05:51 AM
ricky's Avatar
ricky
Default Wanted
Looking for a few bits for serria
front arb mounting brackets
the 2 washer and nuts for the end
A rear arb with brackets
Rear drive shaft the c clamps for the allen bolts which bolt to the diff flang
Old Apr 29, 2020 | 08:53 PM
Mark V8's Avatar
Mark V8
What model Sierra mate ?
Old Apr 29, 2020 | 10:52 PM
ricky's Avatar
ricky
Hi mark it axr4i originally track car trying roolingshell tryinng to fit it up
itsgot cosy 4wd rear with granada 5stud hubconversion
Old Apr 30, 2020 | 07:52 PM
Mark V8's Avatar
Mark V8
I've got a scabby pair of 2WD Cosworth ARB clamps down the shed.
Depends on what anti roll bar you are planning to use ?
Decent poly bush kits come with new washers and the nuts are nothing special
Old May 4, 2020 | 11:18 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i've got a 16mm rear arb with bushed and brackets in the shed if you need, just no links. i also have a brand new bottom arm bush kit which i believe has washers and possibly even nuts. will have a look tomorrow hopefully.
Dave Hewy
Jun 27, 2010 06:59 PM
baggydog
Apr 25, 2010 09:30 AM
Rippers
Ford Escort RS Cosworth
Oct 3, 2006 09:47 PM
