Dump valve Mk4 Rs Turbo
Old Apr 26, 2020 | 06:53 PM
28psiCY's Avatar
28psiCY
Default Dump valve Mk4 Rs Turbo
Hi guys!
​​I'm a current owner of a mk4 Rs turbo. Vehicle is running efi conversion, cossie green injectors, water injection, stage 3 head, Accralite pistons, Burton rods and a stage 3 turbo technics turbo.
As I was on the dyno last year (237whp at 1.2 bar) I noticed my baileys twin piston dump was not dumping the boost out, and all I could hear the actuator. Sadly as on the dyno my T34 hybrid blew before we could take it to our 2 bar target.
Is it possible that the turbo detonated due to the fact the dump valve was not releasing the boost pressure and the pressure went back to the turbo?
I have replaced the turbo now with a stage 3 T3. Should I replace the spring on my twin piston baileys dump valve? Was thinking maybe now I have gone efi it should be a single piston dumb valve for a fiesta RST. Or perhaps just removing the dump valve all together.
Any advice or recommendations would be highly appreciated.
Thanks!!
Old Apr 27, 2020 | 07:43 PM
Bullrst's Avatar
Bullrst
I have one running efi and omex ported polished head among other things i binned the dump valve and never looked back they serve little purpose unless ur running massive bhp-if you went efi you should get wastegate flutter which sounds much better and the car will run better....hope this helps mate
Old Apr 27, 2020 | 08:00 PM
28psiCY's Avatar
28psiCY
Thanks mate.
​​​​​​Dump valve in the bin tomorrow!
Cheers 👍
Old Apr 27, 2020 | 09:03 PM
Bullrst's Avatar
Bullrst
Glad to help out let us know how it goes 👍👍
Turbotodger
Nov 5, 2012 10:50 AM
plynchy
Jun 6, 2010 09:17 AM
Cozzy111
20
Oct 5, 2009 06:08 PM
trev1976
Aug 14, 2007 08:46 AM
AJC
Jan 23, 2006 04:57 PM
