Under body stone gard
Old Apr 10, 2020 | 07:05 AM
COLEYST200's Avatar
COLEYST200
Default Under body stone gard
Hi I'm on the lookout for a good under body stone gard that hopefully will have a bit of a shine to it . I was looking at the U POL Gravitex plus HS stone gard stuff but it says when it's set hard it has a mat finish . They do say that if you add 10% of enamel it will help to bring it up a bit better . But this is starting to sound a bit on the messy side . If it has to be it will have to be but just thought I would put it out there and see wot you lot have used in the past . It can be painted over but just move messing about
O I'm looking to do the underside in white
Old Apr 10, 2020 | 07:37 AM
Mark V8's Avatar
Mark V8
I used tintable Raptor under my rear arches, it dries with a bit of a shine but I over painted it anyway.
If you use a paint gun with a large hole and thin it down rather than shultz gun the finish is reasonable.
https://www.buzzweld.co.uk/raptor-bed-liner.html
Old Apr 10, 2020 | 07:53 AM
COLEYST200's Avatar
COLEYST200
Are I have looked at that stuff is bed liner stuff so it should be hard wearing
Old Apr 10, 2020 | 03:19 PM
MK5 ESCORT's Avatar
MK5 ESCORT
I used gravitex and 2k'd over the top.
I have used 2k mixed in a pot thick enough to brush over for when/if it chips, or i can thin it back down to apply it with a gun.
Old Apr 11, 2020 | 07:11 AM
COLEYST200's Avatar
COLEYST200
Thanks mate for your reply iv been chatting to some mate about this and iv made up my mind and iv gone for the upol gravitx . I ordered 6 cans with the gun to put it on last along with lots of uver stuff for doing the under body restore on my 3dr cosworth
Old Apr 11, 2020 | 02:29 PM
burnzy's Avatar
burnzy
burnzy
Your 3dr can’t be that bad, it was one of the cleanest underbodies I’d seen when I last seen your car, admittedly that was a few years ago 😂 you had the focos on a spit on the drive the last time I seen you guys 🤣
Old Apr 11, 2020 | 09:26 PM
Rsmat's Avatar
Rsmat
Buzzweld W.A.R is the bollox.
Old Apr 12, 2020 | 04:53 PM
dingla rs's Avatar
dingla rs
Raptor mate great stuff
Old Apr 13, 2020 | 07:20 PM
Adam-M's Avatar
Adam-M
Used raptor on mine very disappointed chips off easily and I followed instructions to the letter, also used upol epoxy primer before I applied raptor
Old Apr 18, 2020 | 11:34 AM
cosworth450's Avatar
cosworth450
what was the finish like from factory? im about to restore my other S1
Old Apr 18, 2020 | 11:38 AM
dingla rs's Avatar
dingla rs
3m bag sealer from factory bit it's not cheap
Ed1
40
May 28, 2009 04:55 PM
m_nettleship
May 12, 2008 07:14 PM
danrs2k
Jan 11, 2007 11:40 AM
icelollies
Apr 6, 2006 05:28 PM
