s1 mud flaps
now that the car is running
its time to catch up on some bit and bobs, im fed up painting the front leading edge of the wheel arch so was thinking about mudflaps of soem sort, found these
what do you thing
budget type
either white or blue
nice or shit
http://rallyspares.tripod.com/id167.html
its time to catch up on some bit and bobs, im fed up painting the front leading edge of the wheel arch so was thinking about mudflaps of soem sort, found thesewhat do you thing
budget type
nice or shit
I have something similar. Not because I like them but they are just there to serve a purpose. Like you say the paintwork gets a hammering - so its one less job to do
You will need to make up some brackets and also drill / rivet them to the inner arch too
Tony
Tony
or gt some clear vinyl (or plasticy?) sticky back sheet stuff
(such a good discription) and put it over where the paint chips off.
i think i will go down tony's road, im sick to death of painting the fookin rear arch, and that clear stuff doesn,t seem to work with all the curves its a nightmare to fit.
cheers
peeps
cheers
peeps
cheers tony
will get them sorted out, might try to make the brackets a bit less rallyish
might try to get the brackets on the inside of the wheel arch but the body kit will probably fook that up
cheers
cheers
these ones have the fittings with them,,
http://cgi.ebay.co.uk/ws/eBayISAPI.d...544714083&rd=1
id like some but dont now which ones to go with
