s1 mud flaps
now that the car is running :top: its time to catch up on some bit and bobs, im fed up painting the front leading edge of the wheel arch so was thinking about mudflaps of soem sort, found these
what do you thing budget type either white or blue nice or shit http://rallyspares.tripod.com/id167.html |
I have something similar. Not because I like them but they are just there to serve a purpose. Like you say the paintwork gets a hammering - so its one less job to do :DD:
You will need to make up some brackets and also drill / rivet them to the inner arch too ;) https://img.photobucket.com/albums/v...9/a5e71c47.jpg Tony |
my car looks like its had em on more then once , but make sure u defo want em or when u take em off they leave some nasty holes in the kit like what i have now :(
or gt some clear vinyl (or plasticy?) sticky back sheet stuff :cry: (such a good discription) and put it over where the paint chips off.
i think i will go down tony's road, im sick to death of painting the fookin rear arch, and that clear stuff doesn,t seem to work with all the curves its a nightmare to fit.
cheers peeps |
tony any chance you could sen us a couple of pics of the brackets etc you used
ta |
Will do later davie, but I just made them from a bit of aluminium angle :top:
Told you it was aluminium angle..... :DD:
https://img.photobucket.com/albums/v...9/fd53b809.jpg Good enough for me :cry: |
cheers tony
will get them sorted out, might try to make the brackets a bit less rallyish might try to get the brackets on the inside of the wheel arch but the body kit will probably fook that up :cry: cheers |
these ones have the fittings with them,,
http://cgi.ebay.co.uk/ws/eBayISAPI.d...544714083&rd=1 id like some but dont now which ones to go with |
© 2024 MH Sub I, LLC dba Internet Brands
