s2 gearbox number?
Old Apr 14, 2005 | 02:26 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Default s2 gearbox number?
hi, just looked on my rst s2, and checking what is says on the bellhousing its says on mine v11. but my mate had a turbo gearbox out the other day and it says v11.2 on it,
have i got a 3i box in mine?, its a 88 spec
Old Apr 14, 2005 | 04:10 PM
digita1dragon's Avatar
digita1dragon
The bellhousing should say 87TT
To test if you have an LSD, jack both front wheels off the ground. Rotate one and the opposite side should rotate the same way. If it goes the other way its a normal diff.
hope that helps
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
