Cosworth 2WD ABS pump/ bleeding brakes
I’ve just replaced all the brake lines and brakes on my car
after 3 years the ignition was switched on
i want to bleed the brakes and I understand it has to be done with the ignition on for the rears
The pump seems to run constantly is this correct f no fluid is in the system ?
ive only ran for 6-7 seconds as I didn’t want to burn out the motor
thanks everyone
thanks everyone
