Brakes on cosworth
Brakes on cosworth
Hi I have a little problem on my sapphire cosworth with the brakes and when you come to stop its if the brake pedal pulses and then finally stops but someone told me it could be ABS sensors playing up
Also, there are teeth on the cv joint that the ABS sensor reads off of, if there are full of shit then it could cause an issue, when you clean the sensor, remember to look in the hole it came out of. Good luck getting the sensors off without breaking them, be patient and use lots of penetrating oil/WD40.
Red_bull
09-08-2015 08:34 AM
