Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Non starter after changing battery
Old Feb 16, 2020 | 06:36 PM
StevePorter's Avatar
StevePorter
Default Non starter after changing battery
Hi I have recently acquired a 1.25 Fiesta for the other half.
The car was slow to turn over but always started. I decided to replace the battery as I didn't want her ringing me up saying it wouldn't start.
I replaced the battery and then tried to start car but it won't turn over. All the ignition lights come on but when I turn the key to start it nothing happens.
Now she is really pissed off at me.
Any ideas anyone
Old Feb 16, 2020 | 07:38 PM
martysmartie's Avatar
martysmartie
Any ideas anyone
Have you reconnected all connections properly? I think these have a relay, so it could be this has lost power. Either way power is not reaching the starter motor.
I don't think the starter is an immobilisation point, which eliminates this, but does the LED go off inside?
Martin
Old Feb 17, 2020 | 05:45 PM
StevePorter
Martin
Thanks for the reply. All connections ok and have swapped the relay.
Old Feb 18, 2020 | 12:11 PM
martysmartie
Ok, so the next thing would be to check whether the relay is switching.
Martin
Old Feb 18, 2020 | 06:38 PM
StevePorter
Thanks for your suggestions on this.
How can I check if the relay is switching
Old Feb 26, 2020 | 11:15 AM
martysmartie
The easiest way would be to listen to the fuse box when cranking you should be able to hear it switch/"click" when energised, if working.
Martin
Fordmad!
Feb 8, 2012 04:10 PM
danfisher
Dec 11, 2009 11:06 PM
Daniel1431
Oct 30, 2007 11:32 PM
lamb chops
Apr 11, 2005 07:31 PM
Dan_L
Jul 1, 2004 10:12 AM
