General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
when fitting a 10mm plenum spacer does it affect how the fuel rail bolts up as i’d imagine it means it will be 10mm further away from the injectors? Using an anembo billet rail on a hart plenum.
Reason I ask is to fix my fuck up I made lol, the o-ring Grove on the flange had a small crack and the face was generally pitted ect so me in my wisdom decided to grip it in the mill at work and machine the flange to remove the groove and clean it up ect.....didn’t realise till I got home that there is a small lip that needs to be a certain thickness for the trumpet section to locate into, now it’s too shallow and the trumpet section bottoms out before closing the gap. So I figured a spacer would fix this, not bother about performance gains.
thanks.
If the thickness of the fuel rail lugs on the plenum are still 10mm thick you might be able to simply mount the fuel rail on the other side of the lugs?
