removing lambda sensor, what size socket?
Old Feb 3, 2020 | 01:27 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default removing lambda sensor, what size socket?
got to change a sensor but the socket won't fit
the socket is 22mm but it won't fit over the nut of the lambda sensor
and no one seems to do any other sizes
using some old school spanners though i've got a 7/8th af spanner to fit over the top but i can't get any grip on it to spin the nut
any options before i do the usual "set fire to the thing" ?
it's the pre cat sensor in my 1.4 fiesta and sits right behind the air box so you can see it, just can't get to the bastard because there's a little depression in the manifold
cheers
Old Feb 3, 2020 | 05:21 PM
t230's Avatar
t230
i use a 22mm spanner or special lambda socket 22mm - its got the groove in it for the cable
Old Feb 3, 2020 | 05:23 PM
t230's Avatar
t230
https://www.ebay.co.uk/sch/i.html?_f...ocket&_sacat=0
Old Feb 3, 2020 | 05:45 PM
stevieturbo's Avatar
stevieturbo
C**t
22 is pretty standard for them
Old Feb 3, 2020 | 08:36 PM
Caddyshack's Avatar
Caddyshack
Always used 22m spanner.
get a long one and heat the end and bend it to the shape you need if it won’t fit.
Old Feb 4, 2020 | 01:11 PM
martysmartie's Avatar
martysmartie
Have you got a suitable box spanner?
Martin
Old Feb 4, 2020 | 07:25 PM
dojj's Avatar
dojj
that's the thing, i removed it using a 7/8ths spanner, took it to halfords to check the socket and it wouldn't fit over the nut
Matt Baxter
Aug 3, 2011 11:08 AM
Richie.
Apr 8, 2006 07:34 PM
georgie1
Ford Escort RS Cosworth
Mar 22, 2005 08:54 PM
Apr 12, 2004 04:14 PM
