Blowers not working
Old Jan 24, 2020 | 07:20 PM
Kevu's Avatar
Kevu
Red face Blowers not working
Good evening all, I'm hoping someone can help me.
I have an 03 focus and before Christmas my blowers would only work on number 4. 1,2 & 3 didn't work at all. There was also a strange noise coming from where the fan motor is located, like a loud whirring sound that occurred when the fan was on and then slowed as the fan slowed when being switched off. I eventually changed the hearing resistor and this got the blowers working on all of the settings, but the noise was still there. Then I drove it to work for the next week and one morning there was a slight pop and my heaters went off and now there is nothing from any of the settings the blowers don't work at all which is really annoying this time of year. What is the cause? Can anybody help?
Old Jan 24, 2020 | 07:39 PM
The Youth.'s Avatar
The Youth.
might be something in the fan housing leaves or tree branch etc this has restricted the fan hence the noise and the pop was the fuse blowing
Steve
Old Jan 25, 2020 | 11:09 AM
Kevu's Avatar
Kevu
Talking
Steve
Thank you Steve
Old Jan 25, 2020 | 12:24 PM
Kevu's Avatar
Kevu
I've just checked all of the fuses and the resistor to see if anything had blown and all are working correctly. There is power to the relay and I've checked all plugs including the one into the fan motor everything seems fine. Could it be the fan motor? The only thing it does is change itself from normal to recirculating mode when I press the button but still nothing from the fan itself
Old Jan 25, 2020 | 12:30 PM
GVK.'s Avatar
GVK.
Sounds like the motor is kaput.
hydro st170
Ford Focus ST
Aug 28, 2015 01:26 PM
Dubhghaill
Ford Focus Range
Jan 30, 2012 12:49 PM
ftalbot
Jul 14, 2011 06:36 PM
edzybo
Nov 14, 2010 12:56 PM
cosworthgirl
Jul 12, 2004 12:26 PM
