MT75 2wd rear mainshaft bearing orientation.
Old Dec 12, 2019 | 03:36 PM
r1_pete's Avatar
r1_pete
Default MT75 2wd rear mainshaft bearing orientation.
I’m starting to assemble my V6 mt75 hybrid..
I have a bit of a concern over the rear mainshaft bearing orientation, on the 4wd box I stripped the open side of the bearing was facing the gearbox, on the 2wd box, the bearing had the closed side was facing the gearbox.
From what I can see, if I fit the closed side towards the gearbox, the bearing will run dry, as there is little to no oil feed to the rearmost housing where the speedo drive is.
the front bearing fits closed side to gearbox, but, the housing has slots for oil feed.
can anyone tell me the correct orientation of the rear bearing?
cheers.
Pete.
kidsRS
Jul 9, 2011 01:10 PM
chrisa3
Apr 4, 2011 06:37 PM
Cosmo
Nov 10, 2009 07:20 AM
wing
Jun 22, 2007 12:59 PM
