Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Ford Fiesta mk3 1.3 1994. Alternator problem.
Old Dec 5, 2019 | 08:03 AM
jmgcordoba's Avatar
jmgcordoba
Default Ford Fiesta mk3 1.3 1994. Alternator problem.
Time ago when I started the engine I could see the red battery light in the dash for some 3-4 seconds or until 30-35 seconds when I started to drive. Couple of weeks ago the red battery light was on all the time. I measured the voltaje in the battery and was around 12V. I recharge the battery and I re installed. Red light continued same, the voltage in the battery with engine running did not reach 13V. I replaced the alternator. Now the voltage in the battery (engine stopped) is 12,72V and 13,95 with engine running, BUT the battery red light continues flashing red! when connecting consumers I see the voltage decreases. I think all kind of things:
i) belt tensión in the alternator. I have replaced the belt. I think is correct tension becasue this car have two belts, this one is for the waterpump and thee alternator, the tighten is made pivoting the alternator)
ii) I have replaced the regulator with the brushes. Same problem
iii) Al the grounding seems to be right.
Please give me any clue or advice. I will appreciate. Thanks in advance
RSMK4TURBO
May 11, 2019 09:55 AM
busa bob
Dec 18, 2011 11:41 AM
BrianEscCos
Mar 19, 2008 09:12 AM
Windle
Jul 18, 2007 11:28 PM
tezza_RS
Jul 8, 2006 04:39 PM
