Im putting a wide body kit on the car so the fuel filler door on the rear 1/4 will be gone.
I have the original tank and really dont want to change it due to its location being near ideal. fuel tank
So the questions relate to that,
What the red circled bit? i have removed it as i no longer have the charcol canister in the engine bay and that attached to that so didnt see the point in it.
Is the green circled item a 1 way valve for the tank breathers (circled in blue) ?
Im going to try and reuse the filler neck pipe and attach a big hose to one of these universal kit car style fillers. Issue is im not sure if i need a vented cap or not? Does anyone know if the standard focus cap is a vented one?
Last thing i want to be doing is messing about with petrol and chucking it out the filler door on track so thought id ask for some advice!
