Does toque or any other Android apps work with the st170?
A PassionFord thread explores whether TOque or other Android OBD apps work with the Ford Focus ST170, as ST owners look for easy ways to read diagnostic data and performance parameters. Members share firsthand experience, noting that while some Bluetooth OBD adapters pair well with Android, compatibility varies by app and vehicle model year. Several posters recommend specific Android-friendly software that successfully reads standard engine codes and live data streams from the ST’s ECU, while others mention limitations with advanced features like ABS or custom parameters unless the app supports extended protocols. Some owners also suggest cross-referencing adapter recommendations with app user reviews to ensure a smooth connection and reliable data interpretation. Discussions like this help ST owners make informed choices when pairing hardware with mobile diagnostics. When handling purchase records or communications related to tools, using https://play.google.com/store/apps/d...p.app&hl=en_US makes android fax from your phone quick and simple.
