Rs Turbo --> Omex , Cossie ISCV quick question..
Old Nov 11, 2019 | 03:25 PM
fatty's Avatar
fatty
Default Rs Turbo --> Omex , Cossie ISCV quick question..
Hi ,
Can any one tell me what the resistance should be across the pins on a Cossie ISCV ?
mine reads 7 ohms , wondering if its goosed because I'm planning on using it for my Omex 600 conversion on my Escort Rs and the manual says must be >12 Ohms.
Many thanks,
Old Nov 12, 2019 | 10:48 AM
davidfox280585's Avatar
davidfox280585
Why use a cossy iscv if going stanadalone? there are other throttle bodies available that are as good or if not better than a cosy one.
I personally use a cavalier v6 64mm unit
Old Nov 13, 2019 | 02:07 PM
fatty's Avatar
fatty
thanks for the reply.
Only reason being i have one lying around and it seems to a path well trodden when converting the RST to standalone.
Old Nov 14, 2019 | 08:21 AM
davidfox280585
I can think of better throttle bodies as the cossy one works I agree however many complain of a dented bonnet.
I personally would use anything but.
an advantage of the cossy one is that it has the iscv built into the body but the downsides are they dent your bonnet.
I am yet to see someone with one fitted not complain of a dented bonnet.
as said I use a Vectra/calibre/cavalier v6 with an external ISCV.
if staying cossy id be inclined to buy a new iscv anyway.
as for OHMS across the pin range I cannot help, try messaging rsmat on here he should be able to test across his on his rst for you
Old Nov 15, 2019 | 12:42 AM
fatty's Avatar
fatty
I have but he's a busy man.
I found a spec sheet on line and they should be 6 - 8 OHMs so mines ok. just trying to establish if OMEX 600 will run it because the hardware installation manual says it must be over 12 Ohms .(?) the guys at Motorsport electronics say ME221 ECU will run it but OMEX seem
to have a wider market etc.
Bonnet is raised anyway so should be ok.
thanks for the input
Old Nov 15, 2019 | 08:18 AM
davidfox280585
only one thing left then is ring either OMEX or Karl at NMS as they are familiar with the omex.
im yet to delve into an omex myself
Roscopeco
Sep 3, 2012 05:42 PM
fatty
Feb 10, 2012 10:23 AM
Sonic Boom
Oct 15, 2009 08:25 PM
Christian and Beccy
Sep 27, 2005 03:12 PM
cozzymatt
Feb 2, 2005 06:50 PM
