Turbo choice
Old Nov 2, 2019 | 08:47 AM
timsrs's Avatar
timsrs
Default Turbo choice
Hi All
with so many choices now for turbo for my Cosworth engine can I get your thoughts on
what you would recommend
my engine which I’m getting from peter Ireland in a week or so
202 block built initially by A1 rally sport and refreshed by peter
it ran in a car giving a reliable 450bhp on a T38
what I’m after is a turbo that will give 400-450 but with minimal lag
what would your advise be on choice of turbo
thanks
Old Nov 2, 2019 | 10:23 AM
cossie51's Avatar
cossie51
I expect most will tell you twin scroll BW EFR turbo and twin scroll manifold as that seemed to be what I was being told.
Yes the EFR turbos are tried and tested and will give you the results but on the advice of my mapper I've decided to try the New Garrett G25-660. I'm having a tubular manifold made at the moment but as you can now get them on a T3 flange you could just buy the turbo and bolt on to standard manifold.
Mine is G25-660 external gated with .92 rear housing. Once the manifold is finished it will all be fitted and mapped so will then have some figures to share as no one seems to have fitted one on a YB engine yet but looking at what they are making on other engines and how fast they seem to spool it should be very good.
Old Nov 2, 2019 | 06:56 PM
markk's Avatar
markk
Holset HX30.
Old Nov 2, 2019 | 09:46 PM
timsrs's Avatar
timsrs
I’ll look into those
nice 1
Old Nov 3, 2019 | 08:53 AM
Caddyshack's Avatar
Caddyshack
Borg Warner efr on twin scroll manifold was great on my car at 470 bhp. Worked very well at 400 bhp on Lower boost too.
Old Nov 4, 2019 | 02:13 PM
R4N SS's Avatar
R4N SS
ive gone for a Holset HX35 on my saph
Old Nov 4, 2019 | 03:17 PM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
What's the spool up etc like on it fella? Heard nothing but good things about holsets in fact it's what were looking into going for on my cvh (he221)
Old Nov 4, 2019 | 04:26 PM
markk's Avatar
markk
HE221w is a mega turbo. I have a couple of them
Old Nov 4, 2019 | 04:31 PM
R4N SS's Avatar
R4N SS
no idea yet as still waiting for my mate to finish the car off - hopefully it will be better than the GT3076r it replaced as that was laggy as hell and then all the boost came in at once which made it horrible and difficult to drive fast
Old Nov 4, 2019 | 05:52 PM
turbotrev's Avatar
turbotrev
Go for an internally gated efr 7064 if it’s 450 hp and low lag you want.
I wouldn’t bother with the new Garrett G25’s if I were you.
not enough out there tried and tested on a yb so could be a huge waste of money....
Cheers Paul
Old Nov 5, 2019 | 03:49 AM
bluntys1rsturbo
Boost addict
Brilliant mate what are you running them on. I hear they are mega responsive and make good numbers.
Old Nov 5, 2019 | 04:32 AM
markk's Avatar
markk
Hi comp YB. Had mine on for the last 2 years. They are lots of variants though. Different turbine housing sizes in particular
Old Dec 10, 2019 | 08:40 AM
trimetrin's Avatar
trimetrin
using GT35r (gt3582r). have 2 maps, on high boost high octane there are 595 hp at the wheels. turbo kick in at 5K give or take up to the rev limiter at almost 9K
Old Dec 10, 2019 | 03:58 PM
cossynut2's Avatar
cossynut2
10 Year Member
What car is the turbo in as almost 9000rpm does'nt sound like a Cosworth engine?
Old Dec 10, 2019 | 04:48 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
I would like to see how the g25 performs on a standard fannymould. That's an upgrade I could actually afford at some time.
Markk is your holset on a standard fannymould or aftermarket tubular affair?
Old Dec 10, 2019 | 05:18 PM
trimetrin's Avatar
trimetrin
engine is 200 fully build. I’m shifting at around 8000 but the rev limiter is 8500-8700.
not sure exactly as the engine was tune before I got it and the original tachometer ends at 7000. Need to get an aftermarket tachometer.
Old Dec 10, 2019 | 05:30 PM
markk's Avatar
markk
Standard 4wd manifold with a T3-T2 adapter.
Old Dec 10, 2019 | 06:49 PM
cossie51's Avatar
cossie51
[QUOTE=Mad_Mat;6803945]I would like to see how the g25 performs on a standard fannymould. That's an upgrade I could actually afford at some time.
I should be able to tell you how the G25 performs in a few weeks time when mines mapped but it is going on a tubular manifold but with T3 flange.
Not found anyone running the new G-series on a YB yet so will be interesting to see how it performs.
Old Dec 10, 2019 | 07:39 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Holset info
some interesting reading on the holset turbos
Old Dec 10, 2019 | 07:40 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
[QUOTE=cossie51;6803953]
Im looking forward to the results. Bet you can't wait to find out how it performs
Old Dec 10, 2019 | 09:16 PM
cossie51's Avatar
cossie51
It's been about 4 months since killing my T34 and deciding to go for a G25 instead of the normal EFR direction most take. Manifold should be finished by next week so not expecting to have any results till early January but as I can't find anyone running one yet it's all a bit unknown and nerve racking but also exciting at the same time
somewhere between 450-500bhp will be amazing with torque to match which I was told it will do without breaking a sweat. Told them to be kind to my engine rather than pushing numbers as not looking to build a new engine till next year then can see what a G25-660 can do when pushed hard.
Old Dec 16, 2019 | 10:08 PM
cossie51's Avatar
cossie51
Tubular manifold test fitted today with Garrett G25-660 to work out the best position for the external wastegate take off. Will be fed back in to the downpipe as don't want the noise of a screamer pipe.
Old Jun 14, 2020 | 02:14 PM
trimetrin's Avatar
trimetrin
any update ?
Old Jun 17, 2020 | 07:24 AM
cossie51's Avatar
cossie51
any update ?
Not at the moment, Garage drilled a exhaust stud they snapped out and drilled in to the water jacket then said it wasn't down to them so collected the car and removed the head once I got it home but due to lockdown and a bit of a lack of interest I've not done anything with it yet !
hardasrs
Dec 23, 2014 09:04 PM
RS 5tu
Dec 16, 2009 06:43 PM
monkian
Oct 13, 2006 03:24 PM
Alps Pacino
Aug 31, 2006 01:11 PM
