Help identifying ford brake reservoir
Old Oct 31, 2019 | 08:38 PM
scoooby slayer's Avatar
scoooby slayer
Default Help identifying ford brake reservoir
Does anyone recognise this brake master cylinder reservoir
I've found a master cylinder that looks identical it's listed as a Sierra one
My cap is home made junk with a hole in it that lets water in and has rusted the master out !
I need a new cap and hopefully a chrome cover for the reservoir but it doesn't look like any Sierra reservoirs I've seen for sale ?
I'm hopeing someone will recognise it
Old Oct 31, 2019 | 11:09 PM
stevieturbo's Avatar
stevieturbo
C**t
Problem is...they all look very similar.
It's very hard to tell from the photo though. It almost looks like yours has only one feed from reservoir to master ? Although that would be very unusual.
There may be some ID markings if you remove it ? Any idea what the servo itself is from ? any brand names anywhere ?
Or just replace the whole master and servo as a unit.
Old Nov 1, 2019 | 12:17 PM
qed296's Avatar
qed296
The reservoir looks alittle like an old volvo or even a beetle type.
If your changing it anyway id take it off to get any numbers off the m/c, has it been modded to allow for the bracing?
The local motor factors should have books with measurements etc to get a replacement.
Old Nov 1, 2019 | 12:33 PM
scoooby slayer
I want to keep it all, figured it out today it's from an f reg Sierra 1.8 pinto engine, I've ordered new master cylinder and cap for reservoir, I'd like a polished alloy cover for the reservoir like I had on my cossies years ago if anyone still makes them ?
focus2351
Sep 9, 2015 09:33 PM
xan_lee
Sep 6, 2012 06:03 PM
EssexMikeSi
Nov 15, 2010 07:09 PM
Brick
Jan 4, 2010 05:03 AM
