Where can I get an OFAM ecu or alternative?
Old Oct 7, 2019 | 08:33 PM
LouMan's Avatar
LouMan
Default Where can I get an OFAM ecu or alternative?
Currently restoring an EFI XR3i that will be running OFAB due to the power I am aiming for (220+) I need to run injectors that are better than beiges. So I’m want to run some kind of piggyback ecu as I don’t want to butcher the old wiring loom. OFAM looked perfect to me but they don’t sell it anymore. I know it’s based on megasquirt but from my understanding you can’t run megasquirt as a piggyback. What can I do???
Old Oct 8, 2019 | 07:53 PM
studabear's Avatar
studabear
Just install a new loom or if you are handy with a wiring diagram you may be able to make a conversion lead to connect the original loom to a new ecu.
I wouldn't want prehistoric wiring running a decent tuned engine.
Old Oct 8, 2019 | 09:07 PM
jsa's Avatar
jsa
Forget about piggy backs, reprogram what you got or replace it entirely. PM Pym over at
http://www.efidynotuning.com/forum/v...it=ofab#p29596
Ask if he has a definition file to share. If so you could fit bigger injectors and reprogram accordingly.
Old Oct 9, 2019 | 03:08 PM
LouMan's Avatar
LouMan
While I can do most stuff electrically I have never done anything engine management wise but have been looking at the omex stuff.Is it possible to find anyone who will build a loom specifically for a CVH.
C05W0RTH
Dec 28, 2010 05:45 PM
radiant red
Jul 12, 2007 05:52 PM
