omex 710 ecu
omex 710 ecu
how much would the above ecu be worth second hand?
i'm going to sell me l8 and buy an aftermarket management and have been been offered a omex 710 but not sure what i should pay.
also would new a full new engine loom? i have a ryan loom at the minute, could i just change the ecu plug or buy an adaptor?
1st to 200 without NOS
You will be able to run coil on plug, 8 inj, launch control etc etc. You will also be able to control your cooling fans with the ecu too.
Worthwhile swap, you can simply replace the pins on the loom you have already but you may have to add some extra wiring as there's loads of extra features you may wish to use, I've just done this on my 500. The ECU new is £845 plus vat, you need to be careful that it has the right drivers for what you want though but even if it's the wrong spec it can be sorted cheaply.
i will only be using 4 injectors.
how will i know it has the right drivers? he just gave me a link to say it's this ecu.
http://www.omextechnology.co.uk/Ecus/710/omem710.htm
i believe it has been run on a non turbo car which way running a coil pack.
DixieTheKid
14-09-2015 09:04 PM
