Mtx 75 ---> ST 170
Old Sep 29, 2019 | 05:17 PM
wrc62's Avatar
wrc62
Default Mtx 75 ---> ST 170
Hi everyone, i'm doing an Mtx75 conversion on my ST170. What type of clutch i must buy? 230mm or 240mm? There is a difference on flywheels?
And where can i find a new OEM Flywheel?
Thanks and sorry for my english, i'm french!
Old Sep 30, 2019 | 02:06 PM
colins2's Avatar
colins2
There is a post on here that has all the information you will require, try the search button.
Old Sep 30, 2019 | 06:02 PM
big_wasa's Avatar
big_wasa
For a new flywheel try contacting one of the several firms that sold the crate engines. Standard 2.0 is 240mm “most” 1.8 where 220mm and being lighter are more desirable.
Retroford
Gbs
Raceline
Dunnel
I doubt you will get one direct from ford. They aren’t that desirable.
Old Oct 13, 2019 | 03:33 PM
wrc62's Avatar
wrc62
Thanks for your informations!
I have an other question, i knoow i must chan gear cables for conversion, but can i use the St170 gear lever and support?
Or i must use a 2.0 zetec gear lever support?
Old Oct 14, 2019 | 08:55 PM
The Black Count's Avatar
The Black Count
Hello, I did this conversion a couple of years ago see my thread " st170 number 2 and 3 "
You will need the complete gearbox including mounting brackets, drive shafts, bearing support, flywheel, flywheel bolts, clutch, gear lever and cables from a mk1 focus 2.0, I can not remember if you also need the hydraulic pipe for the release bearing.
After the conversion the speedo will not work correctly, I did purchase a corrector module but did not fit it so do not know if it works
Old Dec 22, 2019 | 07:03 PM
wrc62's Avatar
wrc62
Hi, do you have a photo of placement of power steering pipes with this conversion? Maybe it's different on LHD and RHD, on mine i don't see how to fit this pipes
Avinitlarge
Ford Focus ST
Mar 14, 2014 10:27 AM
Phil Walker
Ford Focus ST
Mar 12, 2013 02:36 PM
RichieST
Aug 17, 2009 06:22 PM
cheeky dog
11
Nov 12, 2008 04:02 PM
