Cosworth interior light/stereo/cig lighter not working
I have a 1987 3 Door Sierra Cosworth.
The interior lights, stereo and cigarette lighter currently don't work.
I know they are all linked and the fault will be common.
Checked all fuses, renewed/cleaned all battery wiring connections.
Now with my limited knowledge I am stuck on the cause.
Any suggestions I could try to remedy?
If like the MK2, everything you mention (along with central locking) is protected by the same (20 A) fuse.
I would advise you use this as a starting place to see if power is present.
Martin
Martin
Does the interior light have power?
Kind regards,
Martin
I will check tomorrow and see , thank you
Jas
Ive tested the interior light, cigar lighter etc and it shows there is a very low current getting through, I think it could be a dodgy earth. Where is the earth to cover these items?
I assume you mean current, not voltage?
Neither of these will draw much current and don't share a common earth.
The earth for the interior light is the door switches, which actually trips a timer relay in this case (courtesy lighting).
I don't believe this to be the issue, but you could always run a test earth if you wanted to.
Martin
Martin
jason_nike
Sep 23, 2019 02:25 PM
escort-cossie-owner
Jan 25, 2005 07:45 PM
