Mines touched the floor while using the solid alloy mounts, so I machined some spacers (I think 6-8mm thick) to give me clearance and also spaced out the steel beam pad to get it parallel
I didn’t really notice much of a difference with solid beam mounts. If you are making a spacer then a hard poly 6mm spacer might give you a tiny improvement in nvh.
I’ll see what she’s like once I’ve got it on the road mate
Went into work on Saturday and knocked up some spacers, still have the beam plate ones to make but wanted to know 100% it was enough before I went too far!
Had to space the centre tube by the same amount - 1/4" to avoid crushing the bush.
