Which is the proper Ford ignition coil number to use with MSD's wasted spark system? I was researching and see Ford has several different ones out there. Do some put out a higher output than others?
The Complete MSD wasted spark kit has everything that is needed.
Yes I was aware of going that route, but I bought a ecu with board installed by MSD, and was collecting the other. Already have the extra amp, stand, bought the necessary harness, wires from MSD. If I could have afforded a new Cosworth I wouldn't be building from pieces! Like alot of mates....I save money where I can.
Yes I came across the MSD 8241 Blaster coil, Summit as well as eBay has them...they claim it has 40kv, but then all the others state that too. I've heard that the stock Ford coils don't have that many issues but I see several different part numbers and they all look visibly the same. I don't see anything special about the one included in the Wasted Spark Kit.
