2wd cossie thermostat housing question
Old Apr 13, 2005 | 09:28 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default 2wd cossie thermostat housing question
Inside my thermostat housing is a thermostat "held" in place by a spring-like piece of wire that locates inside a groove in the housing, but the thermostat is rattling about.
Now, is that normal, does it locate in place with water flow, or, should there be a rubber seal in there to positively hold the thermostat in place ?
If so, what is the sequence for re-fitting, seal, thermostat, spring, or, thermostat, seal then spring ?
Thanks in advance
Old Apr 13, 2005 | 11:34 PM
richm's Avatar
richm
from memory it's like a pinto - rubber ring, then thermostat, then clip to hold it in against the rubber
Old Apr 14, 2005 | 06:26 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Old Apr 14, 2005 | 07:14 AM
frog's Avatar
frog
Perfect, glad you described it cos I have no idea what it's like on a pinto
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Harryh24
Aug 26, 2015 07:50 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
