Puma/Fiesta conversion wiring ??
Old Jul 30, 2019 | 04:39 PM
Adder's Avatar
Adder
Default Puma/Fiesta conversion wiring ??
Hello folks,
I think this should be straight foreword but I'm making a meal of it as usual ! I've bought a complete running Puma same year , same digital loom as my Mk4 Fiesta. So far so good right , whilst everything is looking very similar the Puma has the MAF sensor wiring running down the N/S inner wing but my Fiesta has' nt got a MAF sensor or at least I can't see one and I can't separate MAF wiring from the loom . I don't have remove the Intire loom and fuse box do I ?? If anyone has done it I'd appreciate it if you could point me in the right direction please?
cheers
adder
Old Jul 30, 2019 | 05:07 PM
st220kyle's Avatar
st220kyle
Yes you do have to swap the entire loom and fusebox, the loom also goes through to the back of the car for the rear abs sensors. It's not as bad as it might first look though
Old Jul 30, 2019 | 05:17 PM
st220kyle's Avatar
st220kyle
You'll also need the puma airbox and pipework to go in the fiesta as the original fiesta setup is slightly different.
Old Jul 30, 2019 | 05:55 PM
Adder's Avatar
Adder
Shit ! That's the last thing I wanted to hear !
I might just re read the guide you sent me to be sure . My car has'nt got ABS so I might get away with the rear of the loom. How are you getting on with yours ??
Old Jul 30, 2019 | 06:19 PM
Adder's Avatar
Adder
Ive just had another thought , surely you must be to connect directly into the Ecu multi plug . It's only 3 pins ????
on another point , my zetec turbo has'nt got MAF sensor . Do I even need one ?
Old Jul 30, 2019 | 07:20 PM
st220kyle's Avatar
st220kyle
The ecu multi plug has about 100 pins! That is part of the engine loom so will also need to be swapped over.
It really isn't that bad to swap over the entire loom, once I had the engine out i was able to remove the wiring loom easily within an hour. Didn't take much longer to get back in.
If you want it done properly and running correctly you need to swap over the entire loom.
Got mine MOT'd start of June then drove it over to Germany and did the nurburgring end of june, had a few minor teething issues to start with but now it's 100%
london_chris
Ford Puma
Jul 18, 2019 06:44 PM
milne101
Ford Puma
20
Aug 10, 2011 09:50 AM
xrsi
Jun 20, 2010 08:02 PM
matt-xr2t
Ford Puma
Jan 27, 2010 10:19 PM
cosrep
Fiesta RS1800/RS Turbo
Dec 21, 2009 10:06 PM
