Connecting the aem wideband to l6 ecu
Old Jul 30, 2019 | 04:09 PM
Fezzrs's Avatar
Fezzrs
10 Year Member
Default Connecting the aem wideband to l6 ecu
Anyone know what pins the analog input are on the l6 ecu positive and negative for my wideband output
Old Jul 31, 2019 | 07:09 AM
oldford's Avatar
oldford
Why would you want to connect an Oxygen sensor to a L6 ecu?
The L6 does not have an input for an Oxygen sensor and I doubt the hardware for it is present if you assume it's the same pin as in the L8..
Also the software that is used will not do anything with a signal from the Oxygen sensor.
Furthermore the standard Eprom is completely full with the standard program and there's no room for a Lambda control strategy.
Old Jul 31, 2019 | 05:44 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
I think you need L8 to run closed loop
Old Aug 2, 2019 | 06:19 PM
stevieturbo's Avatar
stevieturbo
C**t
And it would make more sense to do that off a standard narrowband sensor as it is designed.
Mad_Mat
Apr 2, 2014 11:19 PM
series_one_rst
Mar 20, 2011 05:24 PM
dannyblackpool
Jun 6, 2006 06:58 PM
Fiecos Dan
May 28, 2006 11:08 AM
