Lynx incorrect timing...
Old Jul 29, 2019 | 09:45 AM
Al Dun's Avatar
Al Dun
Default Lynx incorrect timing...
Hi all, looking for some advice, doing a wet belt to chain conversion on the kkda 1.8tdci,
Inserted the crank timing pin and rotated the crank till it stopped against it, in this position the cam slot isn't level, it's 10degress btdc..... the timing mark on high pressure pump pulley is also out. The engine was running but does that mean the timing was wrong or am I missing something?...
Old Aug 5, 2019 | 06:58 PM
Adder's Avatar
Adder
Did you get the Ford kit that comes as a cassette type deal that just fits on or did you get the after market kit that you put together yourself ? If it's the latter you mat have a tooth or two out also, are you sure you have got the right length crank pin ? Hope this helps
adder
Old Aug 7, 2019 | 09:09 PM
scoffstainland44's Avatar
scoffstainland44
cam pulley is not on a woodruff key you need to undo the bolt loosen the pulley and set the cam level across the slot
Bailes1992
Dec 22, 2014 06:38 AM
tutuur
Ford Focus Diesel
14
Nov 3, 2013 08:47 PM
Bailes1992
Sep 13, 2012 05:55 PM
Shandy-Ade
Jan 26, 2008 07:49 PM
