Help needed. Fault code p0458
Old Jun 9, 2019 | 09:15 AM
Daniel mcg's Avatar
Daniel mcg
Default Help needed. Fault code p0458
Have a 07 st focus and I Have this code. it’s for the Evaporative Emission System Purge Control Valve Circuit Low Input. Not sure what parts of change out to resolve the fault. Has anyone on here have the same fault.
Cheers dan
Old Dec 24, 2020 | 05:15 PM
Sebastian Lis's Avatar
Sebastian Lis
Default I’m having the same problem in 2020
Cheers dan
hi can you please tell me if you have found the solution as I’m having the same problem and now the car doesn’t start, first the code you have mentioned was showing and it was hard to start but no it doesn’t start at all.please let me know if you have sorted the problem.
devilboy666
Mar 20, 2012 07:07 PM
rich123
Dec 13, 2011 08:42 PM
stevie-c
Ford Focus RS
Sep 30, 2009 09:58 PM
PeteS2RST
May 29, 2007 06:54 AM
