ST170 Engine rattle
Morning all! Hope you had good weekends!
I recently bought a 2002 Focus ST170.
The exhaust was rattling like crazy so i swapped out for a mongoose cat-back and toyo sports manifold and decat. However now it’s worse and sounds like an engine noise, the engine was quite tappy before and still is but runs and drives mint. I haven’t ran it on the road at all since fitting the new manifold because of the rattle getting a lot worse.
any help would be greatly appreciated, I will post a video later on today for anyone interested.
Kind regards,
Jamie Allan.
Kind regards,
Jamie Allan.
the dual mass and vvt can cause lots of rattle on these cars thats if the rattle is not from core of engine itself, I break 170s all the the time and most common causes are normally the dual mass and vvt, and this is normally main reason I break them when people see a bill for a dual mass and clutch kit for around Ł500 and the vvt pulley and solonoid Ł250+ thats parts only no labor, normally why these cars sell cheap on the 2nd hand market
My dual mass rattled for 5 years of owning my ST170, it never slipped or broke, despite being used daily to and from work, and hooned at the weekend
What's the oil like, and what weight are you using ? also have you checked the heat shield on the manifold, as well as the cat heat shield ?
Running 5W30 oil, the last service a few weeks back I was told to use 10w40 with some lifted fluid to try solve the tapping notice but had little to no effect. Now that’s all flushed I will be using 5W30 again. Il post a video once she’s running again if it’s still rattling lol.
cheers for all your reply’s
