Aluminum header tank and swirl pot
Is there a real benefit in fitting a aluminum header tank? I’d like to fit an uprated cap with a higher opening pressure to increase the cooling capacity. But can the standard header tank take the increased pressure? I guess the aluminum tanks are ok with the pressure, but I don’t like the fact that you cannot see how much coolant is in there. I know there are tanks with a small glass in there, but still the original tank is more convenient. So why do people change?
And what is the reason to fit a swirl pot?
I went aluminium as I’ve had the plastic one swell slightly from a fast road drive so going to be using the car on track and didn’t want to risk it, got one with a sight glass. Swirl pot as mentioned above is meant to remove any little bubbles caused by heat in the head.
Thanks for the info!
Does anyone have an Airtec header tank with sight glass? It’s bit cheaper than the Pro Alloy and Spec-R one and looks good to me, but there are no clear pictures of the sight glass.
I hardly see any second hand Cosworth items appear on the internet anymore. The for sale section here gets about 1 post a week. Where did you find yours on Facebook?
I'm happy to give away my set for free as I do not think I will put them back, plus I no longer have those coolant piping. Just buy me drinks when I happen to visit Netherlands in the future
Thanks, that is a great offer and I definately would like them!
If you are in the Netherlands we will definately have soms drinks!
I will send you a PM with my details.
EssexMikeSi
Sep 26, 2011 12:56 AM
Big Will_
Apr 6, 2010 12:54 PM
XRT_si
May 29, 2009 11:27 AM
georgie1
51
Jul 14, 2006 11:53 AM
